I’m looking for a customised mirror with mdf backing 1850 x 1100 for bathroom.
Hello @ianwsmith76
Welcome to the Bunnings Workshop community. It's fabulous to have you join us and thanks for sharing your question about a custom sized mirror.
I'm sorry but the largest mirror the store has is the Living Elements 1200 x 900 x 5mm Flat Edge Mirror. This has vinyl backing for protection and does not have a timber frame. The closest way for you to have the size you are after is to put two Living Elements 900 x 900 x 5mm Flat Edge Mirror together.
This would give you the 1.8 meters you are after. However, it will be necessary for you to build your own timber frame for the mirror if that is what you are after. I also suggest using either pine or plywood as MDF does not do so well in high moisture environments.
