I have never tiled before but have grouted, so I wanted to tackle this small project of re-tiling this laundry wall with some smaller mosaic tiles that go from just below the bench height right up to the cupboards.
I plan to get an electrician and plumber to help me with capping off / possibly moving the PowerPoint and taps.
My issue is that when I removed the tiles from the side wall (side of the sink) it damaged the gyprock a fair bit - small enough I am able to repair in that location, but large enough that I don't want to tackle it on the main wall as I'm certain I'll end up with loads of holes.
Can I add a 6mm panel of... something (plasterboard?) at the top strip between the existing tiles and the cupboards to make it level and then put the new tiles all the way down?
Or am I better off attaching a whole new substrate over all of it, and tiling onto that?
Or do I just remove the existing tiles knowing I will probably smash up the wall, and then replace the gyprock?
