Hi
I am wanting to build a small 3m by 3m deck with pergola. The decking material will be composite decking. A landscape architect drew a simple plan for me -see photo below. I would really appreciate help in locating generally stocked items from Bunnings for the build (im in Ashfield, Sydney).
He said to bolt 100mm x 100 mm posts to the small wall at back of yard (see yard pic below). What height would you recommend?
Could you advise with link to best posts to use from Bunnings please. The posts will be painted.
The bearers are drawn as 100 mm x 75 mm - again can you advise with link to best timber to use from Bunnings for these bearers please.
The rafters are shown as 75mm x 50 mm - can you advise with link to best timber to use from Bunnings for these rafters please.
(if these sizes are not stocked pls advise closest suitabe that is stocked at Bunnings pls)
Regarding the posts at the front of the deck (not bolted to the small wall at the back), they will sit on a slightly sloping concrete slab - what is the best way to "seat them" onto the slab?? (prefer not do dig into slab if possible as there may be a drain there)
What type and size timber would i use to join the top of the posts for the pergola and and cross members?
Many thanks
