Hi
How do i make a Simple version of this cat enclosure, any ideas please and what materials would i need It doesnt need to be as high but needs to have space ?
Thank you
Hello @Lboyd
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your your question about building a cat enclosure.
I suggest having a quick look at these discussions - D.I.Y. mesh cat enclosure by @Chrissie35 and How to build a catio? by @Mel_K. Building the frame does not have to be overly complicated. It is basically a square or rectangular frame.
However, adding a roof means that the frame has be strong enough to hold the weight of the roof frame and the roof sheets. otherwise, if you are just covering it with tarp or bird netting then you can keep the frame simple. How big did you want the cat enclosure to be? What surface will yo be building on and was there anything specific you wanted to install in your cat enclosure?
