I wish to replace my current privacy screen with horizontal treated pine slats.
I like the look of these channels provided by Jack they are the correct height and I wish to use them:
https://www.bunnings.com.au/jack-1-1m-19mm-slat-rear-fix-screen-up_p1100727
The issue is the span is 3.4m and the base timber only has 20mm of overhang which makes it difficult to use an L bracket to fix a vertical support in the middle.
What is the best approach to the job and will using several braces be enough in this situation or do I need to use sturdier support?
Cheers!!
