What is the towing capacity on 2024 Ryobi ride on mower
Hi @andysun09,
Thank you for your question and welcome to the Bunnings Workshop community.
Can you advise which model of Ryobi ride on mower you are referring to? I will be able to do some research and make some enquiries if you can advise a specific model.
Let me know if there are any questions you have.
To follow up, if you are asking about the Ryobi 38" Battery Ride On Lawn Mower, the manual states that its towing capacity is 226.8 KG.
Let me know if this is not the model you are after, and I can do some more research.
Hi jacob. Its a 48e. 42 inch cut
If the mower you are referring to is this Ryobi 48V 42" Brushless Zero Turn Rider, the towing capacity is the same as the one I've mentioned earlier, 226.8kg.
If this is not the correct one, can you please advise the model number which can be found in the details section on the product listing on the Bunnings website. See below.
Let me know if you require further assistance.
Hi Jacob. I may have my facts wrong but does Ryobi have a 48v 42 inch cut ride-on that steers with a steering wheel? Not Zero turn.
It was bought about 2 months ago
Here is Ryobi's range of ride-on mowers. There is no 48v 42-inch model with a steering wheel. Would it be the RM480E 48V 38" 75Ah Brushless Ride-On Lawn Mower or the RM300E 48V 30" 50Ah Brushless Ride-On Lawn Mower that you have? There should be a compliance plate on the machine which you can use to verify the model.
