TV Conduit to 90mm stud internal wall – how to plan? Share pictures to get idea.
what will be connected to the TV, leads to the question how many and what size conduits (50mm pvc pipe ? ) will I need installed in the wall to allow the greatest flexibility in the future.
Need double GPO, antenna to be mounted at the top (1200mm? above FL), double GPO at the bottom (300mm above FL) and a 50mm(?) conduit between top and bottom for either an optical out from TV to soundbar or HDMI from media player at the bottom.
But I'm not sure where I should run the conduit for LAN cable to, top or bottom? plug it to smart tv or plug it to the media player (or even both?). Is it possible to run one conduit with two openings (top and bottom) to allow this setup?
