Hi - am renovating a kitchen at an investment property (ie installing new cabinetry/bench/oven etc) and interested to know what board material is typically used for walls and whether one material would usually go behind all cabinetry or a mix of materials would usually be used.
The existing kitchen cabinets were installed directly to studs so after cutting the boards with tiles away, I’ll be left with basically studs/frame only, which I will board up.
I could use all standard drywall, but it’s not moisture resistant.
So I could use drywall plus moisture resistant drywall behind the sink/splashbacks.
Then I have the stove area to deal with, I could get some fire resistant fibre cement board to put behind the stove.
So now I could have 3 different types of board/wall material for one kitchen.
Is this usual, or would one typically do it all in say the moisture resistant board only (eg aquachek), or all in the fire resistant fibre cement board? Or a combination of water resistant/fireproof?
