Hi
I'm in the process of slowly renovating my kitchen and have successfully painted the wall tiles using White Knight Tile and Laminate paint.
I also want to paint my benches using the same product.
The question I have is in regard to the Bench Top Protective Coating. The area I have to cover is quite small and will only use maybe 1/4 of the product and as it is around $130 per tin I was hoping that there was another product I could use instead as a protective coating.
Also the pot life of the protective coating once mixed is 1 hour and a second coat needs to be applied within 8 hours so it seems that I might have to purchase another tin of coating or will the first coat dry sufficiently within 1 hour.
Thank you
