Hi, I am a newbie, so be kind to me.
I want to build a deck over concrete for a Lazyboy inflatable spa.
This is what I am planning:
1. Build a square using treated wood.
2. Use a screw pedestal system to level the square - what are these called?
3. Add joists every 300mm.
4. Cover with decking
Questions I have:
1. How big should the deck be for a 1.80m diameter spa? - I don't want to do any cutting! Also would like to put a portable gazebo over it.
2. Do you use the same wood for bearers and joists?
3. Do you need to use brackets to attach the joists or can the simply be screwed in?
4. How high off the ground should I build it.
5. Do I need to put noggin things in? If so where?
Thank you for you help. I can do this!!
