Want to put up a lattice feature using the plastic lattice will I need to frame it.
Hello @susanamy
Thanks for sharing your question about building a lattice feature. Would it be possible for you to specify which lattice you're referring to? Generally, if the lattice is soft and flimsy then it would definitely need to be framed up if you are putting it up against a wall.
If it's going outside, the frame will need to be rated for outside use and for extra protection a coat of paint should be applied.
Thanks Eric was going to use the plastic lattice to go on the wall I see there is a frame to suit available, my last one was wooden but now deteriorated so feature needs freshening up
Hi @susanamy,
If it is the Matrix plastic screening then using their frame would certainly be the way to go. Let us know if you have any questions during the installation process. We're here to help.
That’s the one I’m looking at just need to decide what colour
Hi @susanamy
Please keep us updated with your progress, we look forward to seeing your lattice feature installed.
