Howdy All
I have been trying to nut my way through building some steps with gabion wall bases and timber tops. I almost have it but there is a difference in heigh between steps of 10-20mm. The rules states the height should be consistant with the depth and the height.
For my example the height is 170mm and the depth is 300mm (I coppied from my front concrete steps)
The gal mesh I am using is 50mm by 50mm (locks me into certain meausurements)
I am not too concerned with the overall depth of the steps as it can be accomodated. It also matches the steel mesh I have.
First step no issues, second step and issues of height turn up..
Once I started extrapolating it did my head in. The figure above the blocks is what it should be, the figure in brackets is what it will be due to the limitations of the mesh sizing.
The figures on the left are what should be, brackets are what will be and the plus/minus difference in height over what it should be.
The gabion basket retaining wall size. The house wall is on the left.
Gabion basket being built (upside down atm)
Gabion basket up the right way waiting for the ties to be put into place, will have 3 or 4 all up as its a Large basket.
The steps will be on the right hand side of the mesh.
Going through the question this morning I am wondering if I try and limit the height of the timber tread to 50mm (the timber is 40mm thick, the timber spacer under it is 20mm which then matches up with another timer spacer under the mesh to screw through to) Then I can have a consistant height of the steps without the 70mm causing the issue. I think I have answered my question lol The first spacer under the timber is to lock them together, maybe I should use steel plate or something else thats only 10mm but solid mmmm
Any ideas or suggestions, and yeah I can change anything at this point (bar the existing large basket size) as I decide to ketch it out first before cutting mesh.
