I am in the process of wall mounting a 75" TV (33kg) using a static bracket. I am able to secure the bracket to two wall studs about 86cm apart. However, there is no middle stud. Would the two outside anchor pointed be enough?
I have wall mounted a 75 inch tv with two studs that didn’t align in the Center. The first stud was 3rd hole from start and the second was 2 holes past midway. So put a third one in plaster board to avoid any movement. It is tilted at 5 and is standing for the last 3 years. You can also mount a MDF board across 3 studs and put the mount on the MDF board
Hi @dylanfosberry,
It all comes down to what the manufacturer of the product calls for in their installation guide.
Unfortunately, due to the risks involved with hanging a heavy TV from the wall, I cannot advise another method of installation that is outside of the manufacturer's specifications.
If the manufacturer of the TV bracket calls for attachment to 3 studs, that means the product was designed and engineered with that level of attachment in mind. This may mean removing the plasterboard to install blocking, or another vertical stud.
I am very surprised based on the spacing that there is not a third stud available. Vertical studs are spaced at 450mm centres so there should in theory be another one between the two you've been able to locate.
I'd suggest picking up a stud finder and double checking that there is not a stud available before moving to a more intrusive solution.
You might like to check out How to use a stud finder for some guidance.
Let me know how you go, I'm more than happy to assist further if required.
