Materials
British Paints 4 in 1 Prep Water Based Primer Sealer Undercoat
Taubmans Mohawk Blue paint
White satin paint
Tube of brown acrylic paint
Timber stain
Taskmaster 34mm Matte Black Cabinet Knob
Sanding Pads
Sugar soap
Painters tape
Timber trim
Wood glue
Glitz Beeswax polish
Tools
Ryobi One+ Multi Tool (sanding attachment)
Ryobi One+ Drill
Handsaw
Paint brush, roller and tray
Steps
Step 1
Step 1. Unscrew all the hutch doors removing the top ones permanently. Remove hinges from bottom doors and set aside.
Step 2. Sand all sufaces to remove the varnish - no need to sand back to bare timber. Clean all surfaces with sugar soap and allow to dry.
Step 3. Cut to size a length of timber trim to cover the indentations left behind from the upper doors on the top half of the hutch. ( this may not be necessory if no damage is showing) Glue in place and leave overnight.
Step 4. Apply two coats of primer on all surfaces except for the main bench top. The hutch is in two pieces so no painters tape was used on the top half at this stage, only to the underside of the main bench top on the lower section.
Step 5. Add a tiny amount of brown acyrlic paint to the white satin paint and mix to give desired shade ( I found the untinted white a bit too stark for this project) Paint the inside of the upper section of hutch and the inside of the lower section.
Step 6. Once dry, attach the painters tape to the upper section and paint the remaining section with 2 coats of Mohawk Blue paint. (use photo as guide ) Paint the doors blue as well.
Step 7. Apply stain to the main bench top. ( I couldnt get the exact colour I wanted so smeared on some brown acrylic paint with a dampcloth.) Rub on some beeswax polish to the surface.
Step 8. Remove painters tape and reattach the hinges to the doors. Attach the doors to the lower cabinet and then attach the handles.
Step 2
Step 3
