I have an in-ground concrete water tank with 2 90mm overflow pipes that have now separated from the tank since the concrete slab on that side has moved - see photos.
The 90mm pipes are about 3m long buried in a sidewalk.
One gap is about 30mm and the other gap is about 15mm so I want to fill the gaps to keep snakes and toads out.
Ideas:
1. cut section of PVC pipe to fit the gap and use sealant that works on damp/dirty surfaces.
2. cut section of water bottle to fit the gap and use sealant.
3. insert a 80mm PVC pipe thru the 90mm PVC pipe then into the concrete tank hole
Hence, the question whether a 80mm PVC pipe will fit inside a 90mm PVC pipe.
Any other ideas are appreciated too!
