When I removed a tile above the bath, it took half the plaster with it. Do I need to put another piece of plaster board under the cement sheeting? HELP
Hi @Jeanagh,
You will need to install wet-area plasterboard in that area to re-install the tile. Typically, in that location, there will also be a waterproof membrane painted over the plasterboard to stop water that sits on the bath edge from being wicked into the sheeting. It's considered a wet area of a bathroom. Grout is also not waterproof, so any water that lands on it can be sucked into the wall. We touched on this in your other discussion about the shower recess. Removing a tile will likely damage the wall behind and also the waterproofing membrane. Membranes can't be patch-repaired, and repairing to most waterproofers' standards would require removing all the wall tiles, new sheeting, and a new membrane. Then, re-tiling can be done.
Hi Mitchell, unfortunately I can't afford to do the whole wall so I'm going to have to patch it best I can. I've already got cement sheeting and the waterproofing membrane from the shower repair ( I ended up redoing that whole wall. Looks good if I do say so). Will just need to get some plaster board. I'll go to Bunnings a see what they have.
I'll include a picture of my shower so far.
This is a little delayed, but wall fixed. Used plasterboard, waterproofing tape, waterproofing membrane and grout. Unfortunately only had one tile otherwise I would have done others. Still pleased with the outcome.....considering I had no. Idea what I'm doing. Thank you for your advice
Love your work @Jeanagh! You'd never know that a tile was removed.
Well done and many thanks for sharing.
Thank you. That is indeed high praise
