Hi all,
I am working on a small area in my yard (3.2m x 3.8m) to install a stepped retaining wall to level out surfaces at both levels. Refer to the pictures below. I plan to use the retain-it metal posts to hold in the 3 x (50mm x 150mm) timber sleepers making the wall 450mm high, the pieces are 3m in length.
1. Are 50mm thick sleepers too thin to hold back the soil? should I go to 75mm?
2. Should I be cutting the 3m lengths into two 1.5m lengths and have a middle post, concerned the 3m sleepers with no middle post may bow over time? I will install an ag line to drain water buildup in front of the retaining wall to the open area as I don't have a connection to stormwater for this small area.
Thank You
