To install acoustic panels, can you get it custom-cut at Bunnings? Is it easily attach to a concrete/cinderblock wall? Also are there any tips for installation?
Hello @MHH,
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about installing acoustic panels.
I'm sorry but the acoustic panel can't be cut by the shop saws. Unfortunately, due to the teeth size and roughness of the blade, it is not ideal and will ruin the edge of the panel. The instructions suggest using a circular saw with a fine-tooth blade. That would be the safer way to cut the panel.
Here is a link to the installation instructions: Install acoustic panel.
If you are mounting the panel to masonry or bricks, I recommend using Ramset 7 x 35mm Green Wall Plugs in combination with Zenith 10G x 30mm Gold Passivated Countersunk Head Timber Screws. For the adhesive, I propose Selleys 420g Liquid Nails Fast Grab Strong Adhesive. Please note that both the adhesive and the anchoring screws will both need to be installed for masonry applications.
