Im building an out door kitchen that incorporates a brick wood oven and BBQ. Can I lay Besser block straight onto the pavers or do I need to pull them up and put down a concrete base.
Thanks for the advice and helpful links . I’ll draw up a plan and send to the community
Hello @Jonah
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about building an outdoor kitchen. I propose having a quick look at this discussion - How to join Hebel blocks and concrete slab? by @paulbwilliams12. It's an excellent example of how you can put Hebel blocks together.
Here is a handy step-by-step guide: How to build a BBQ bench.
In regards to the base of your kitchen, I propose building a concrete base and pulling out your pavers. Pavers are often loose and prone to movement. These movements will affect the stability of your kitchen. Whereas a concrete base, if prepared properly will provide a solid non-moving foundation for your kitchen.
Here is a handy step-by-step guide: How to pour a concrete slab by @tom_builds.
I propose drawing a plan on paper and sharing it with the community. This will give our members a better idea of what the wood oven and BBQ will look like in your setup. You can then share specific questions you might have about your kitchen plan.
