I can't work out how to open the light shield to replace the heat bulb inside the Martec linear bathroom light and fan.
Anyone know how to do it or have done it before who would kindly advise? Hoping it doesn't require full dismantling of the unit's casing to change a bulb!
I believe it is this model:
https://www.bunnings.com.au/martec-40w-linear-3-in-1-bathroom-heater-exhaust-fan-and-led_p0249655
Hi @housie,
Having a look at the instruction manual, it looks like there are 4 screws concealed by silicone covers at the ends of each vent.
You will need to remove the screws and then remove the fascia to allow access to the inner workings of the unit.
Once this is removed, you will be able to remove the glass from the heating unit to reveal the heat lamp.
You will then be able to replace the heat lamp with a suitable replacement.
Thanks @JacobZ , that's very helpful.
