Hi Team,
I need some advice please to install a privacy screen which will also be used as a trellis from the corner of my house out to around 3m. The primary reason here is to block the afternoon summer sun.
Looking at 3x Jack Matrix 2.4m panels side by side, or the Jack Up with timber slats in between. My block has a 7 degree slope.
If I go with the Jack Up and timber slats, could I start with the Jack Outdoor 19mm Slat 2m Rear Fix Screen Up screwed to the corner of the house and then have around 2.4m to 3m timber slats going out to an end post? Which end post would I use, is it the Jack Screen Up Anchor Plate ?
should I start from the wall, and end up with a single anchor plate and post into concrete? Can the slats be 3m long? How deep does the concrete need to be? Can the Jack Up go to 2.4m high?
Should I opt for the Jack Matrix panels, how could I install those to keep them level at the top and bottom? Should I start from the wall, or a concreted post? If I go with the concreted starting post, I assume I'd need a galvanised bracket set into the cement to brace the post; given the slope of the land are there brackets with long necks or...?
Thanks, I think I need a coffee and a lie down.
I'm leaning towards
The Oven of Death
