Hey Team!
This is a meaty one - thanks in advance.
So, I'm in (what I certainly hope) are the final stages of a garage conversion.
I've framed, plastered & painted. I've purchased Floating Floor which according to their specifications already has a 1MM EVA underlay layer... Though it also recommends adding a poly-film between the concrete and laminate - so I was planning to use this although would've preferred not having 50m of it!
The floor is 10m x 4m and (in most places) is within the specs the manufacturer requires for level and slope.
There are 2 places however that are not in spec.
Place 1) There's a channel appx 3m long and <1m wide with a max depth of 15mm
--> It seems to me a self-leveler would work well here... I'd love to know what the difference between these 3 is:
https://www.bunnings.com.au/lanko-20kg-133-pro-level-floor-leveller_p0966662
https://www.bunnings.com.au/sika-20kg-sikafloor-level-pro-underlayment_p0760431
https://www.bunnings.com.au/bastion-20kg-floor-leveller_p0273642
I don't think the #1 or #3 speak to coverage, so I'd be inclined to go with #2. #3 also doesn't like to go deeper than 12mm.
#2 also speaks to 'bulking out' with aggregate to reach 50mm thicknesses - which may be useful for my 2nd Place.
The Plan
Given we're essentially just 'filling a hole' here, apply Primer, mix self-leveler, pour slowly, trowel if needed.
Wasn't going to bother with a spiked roller to remove air-bubbles e.g this particularly since I'm not overly concerned if the final surface isn't perfectly smooth, with laminate going on top.
Place 2) There's a 4m long 1m wide section along the wall, sloping downwards towards the wall at a max height of 25mm.
Based on the coverage of self-leveler #2 above, I'd imagine I might need more than 1 bag, which I'm hoping to avoid, given the cost.
My thoughts here were:
1. Use concrete @ $8 a bag and then add a light self-leveler topcoat in the event it is needed (first-time concreting, although extensive plasterer, so not my 1st rodeo on a trowel 👍) - downside being the dry-time.
2. Use some ply / MDF / OSB - downside being the risk of moisture
3. Use some cement sheet - downside being you can't easily cut it to size and that it's not particularly cheap.
4. 'bulk out' the Self-Leveler with some Aggregate maybe this one although it's not within the 1-2mm the Sika PDS mentions - any advice on how to do this? Which aggregate to use and any downsides of doing this e.g rough impact on drying time?
The Plan
To avoid splashes:
- Cover the lower corners of the plaster in painters tape / drop sheet
To prevent the self-leveler running under the plaster (given that's where the slope leads):
Apply Primer, mix self-leveler, incorporate aggregate, pour slowly, trowel.
Once dry, I'd imagine it will be worthwhile to then add a 'top layer', in the event the aggregate is visible?
1 other question relating to both pours - given the floor is on a 5mm slope overall, is this likely to affect the self-leveler?
i.e is it going to 'pool' slightly higher on the lower point? Or is there some 'minimum threshold' it wouldn't self-level over in the span of the time it takes to start setting?
My guess would've been that it's not an issue, or, that I'd very lightly re-trowel it after 5-10min to prevent it from doing this.
Thanks so much
