In the process of installing a puddle flange into the shower area. I'm looking at installing a linear drain hard up to the tiled wall which is parallel with the shower sliding door. Linear tray is 100mm wide and drain Spiggot is 72mm in diameter. I've been told to install a 100mm puddle flange to accommodate the 72mm Spiggot. However, dur to the diameter of the puddle flange it would need to be cut or modified to get it that close to the wall. OR is there another type of flange I should be using ?
