Hi all,
I am having some designs drawn up for a raised deck attached to my house.
The deck height will be 1200 from the ground and will be about 8m x 3.4m.
My question is, how do I attach the deck to the house, is it common to attach a ledger board to brick veneer, my understanding that brick veneer cannot take lateral load. So that would mean attaching a ledger to the bearers under the house. Although this would mean that I would drill through the brick and lag screw the ledger into the bearers for support.
I am not sure if this is the best approach.
My other thought was to use the existing piers supporting the house and running bearers off this, but this might be tricky to get the required height. The last option is to have posts closer to the house, and would require more posts than what I really wanted.
Would be really keen to hear your thoughts, as once I figure out the direction, the rest should be straight forward.
Thanks,
Alan
