Hello there,
I recently purchased a shed online, and I've quickly realised that the temporary anchoring pegs won't be enough to secure my shed in place. I know that ideally, a concrete slab would be the best to secure the shed to, but I am wanting an option that I could potentially move in the future if needed.
I was wondering if a paver base would be secure enough to secure the shed to, to give the shed a good amount of weight.
My plan was to put 9x
Custom Concrete Products 600 x 600 x 40mm Plain Pavers ontop of 30mm of road base and sand (dug out level with my ground).
The shed is 1.5m x 1.5m, and I thought I would secure 8 of the pavers to the shed with concrete anchor bolts, which would give the shed a total weight of around 260kg. Do you think this would be secure enough? Should I do anything extra such as securing the pavers with mortar?
I know there will be a slight amount of pavers around the edge of the shed given the size of the paver base will be larger than the shed, but I was wanting to ensure I could avoid securing the concrete bolts right onto the edges of the pavers.
If possible, could you also advise which bolts/anchors would be best to use with the pavers?
Thanks for any tips.
