I have a Masport 625ex - Chip, Mulch, Catch rotary mower. I am trying to remove the chipping blade as I believe the four bolts that hold it in place have sheared due to a collision with a rock.
After removing the quad cut blade carrier (similar to the image below) by removing the central bolt and spring washer, I cannot see how to remove the rest of the assembly from the base of the crankshaft.
The part that is highlighted below, needs to be removed from the crankshaft as it sits below the chipper blade, but I can't see how it comes apart.
