How do I mark out a 4 x 3 concrete slab for a pergola so that it is square?
Hi @aroebuck,
The simplest way, which works perfectly with the size of your concrete slab, is to use the 3-4-5 method.
Pick the side or corner that is most important. It may run off of an existing slab or be relative to a fence and mark it with a stake or marking paint. Once this first corner is set, measure out your sides and place a temporary mark.
You can then measure diagonally across the rectangle to determine squareness. The diagonal measurements, should equal 5 metres. If it doesn't adjust your marks slightly until both diagonals equal 5 metres and then place your more permanent mark.
Here's a couple of handy guides that should help -
