Hello I have white powder over leaves and some leaves are turning brown and dying. Is this powdery mildew?
Suggestions on treatment? It's spread across 4 of the same type of tree.
Thanks.
That sounds like a good solution @Mark_I.
Thanks Mitchell. I was actually going to buy this one tomorrowYates 500ml lime sulphur concentrate as looked like it covered more of this issues that look present. Possibly even the leaf curl.Thoughts?
Hi @Mark_I
Looks and sounds very like powdery mildew, so the treatment suggested by Mitchell would be the way to go!
Make sure the cover the leaves well, including the undersides, for the best results.
Welcome to the Bunnings Workshop community @Mark_I. It's terrific to have you join us, and many thanks for your question about plant care.It certainly does give the impression that it could be powdery mildew, which can be resolved with the application of Yates 150g Mancozeb Plus Garden Fungicide and Miticide. Spray the plant and then repeat every ten days. It is important to thoroughly cover all plant surfaces, including the undersides of leaves. Do not apply if rain is expected within 24 hours, if temperature exceeds 27ºC, or if plants are suffering from moisture stress.
Let me also mention one of our horticultural experts, @Noelle, to see if she has some thoughts.Please let me know if you have any questions.Mitchell
