Hi everyone
how do I go about fixing this minor crack in my bathroom sink?
Hello @siya
Yes, that will work as well, please make sure to wear disposable gloves so that you can sculpt the silicone into the crack. Please note that the silicone is not as strong as the putty, and you might need to replace it from time to time.
Welcome to the Bunnings workshop community. It's sensational to have you join us, and thanks for sharing your question about your bathroom sink.
If there is a chip on your sink, I suggest using PC-11 56g White Epoxy Paste to patch the damage. My best advice is to mix only what you need and sculpt the putty in the same shape as the basin. It can be sanded down if you wish but it would be less work if you can feather the edges so that you won't have to do a great deal of sanding. Please note that the putty will dry off white and will not match your basins colour. For a quick touch up, I propose using Rust-Oleum Tub And Tile Touch Up Kit.
Thank you!
It’s a very small crack- I was recommended the off white silicon sealant in ivory- would that work better?
