Good afternoon,
Would 70 x 35 be strong enough to use for making garage shelving or would it be better if it was 90 x 45?
Thank you
Hello @kelso101
It depends on the items you'll be putting on top of the shelves. Medium to heavy items or Christmas decorations, duvets, miscellaneous plastic containers. 70x35 would be ok for light to medium items, but anything heavier, then its best to use the 90x45. I recommend having a very long ponder on what exactly are going on these shelves and if it's worth using the 90x45 for the entire project.
Do you have a sketch of your shelving plan? Would it be possible for you to share it with us? We'll then have a better idea of what you're trying to create. We can then offer more recommendations on how to build your garage shelving.
Hi @kelso101
It depends on length, depth and load weight. If they are to be larger heavier duty, I tend to always go 70mm x 45mm. 45mm also provides easier access to drill pilot holes and drive in shelf securing screws.
But as @EricL mentioned, an idea on your requirements would help to advise.
Nailbag
Thank you for the responses. The shelving would have a bit of heavy loads such as folding chairs, Christmas deco and heavy duty containers. I haven't made a sketch yet but will be soon. Just wanted some feedback on what timber can handle those loads.
Was thinking of 2.4m length, about 1.8 m in height and around 500-600mm in depth. Will be under some heavy duty casters so be able to move around the garage
Hi @kelso101,
70 x 45mm would be the better option for that size. With a width of 2.4m, I'd recommend you install a mid-support to prevent the shelves from sagging.
