How to repair, plaster or painting a 50 years old brick walls of garage. Lot of cracks and holes on the walls.
I plan to DYI this job. What's material and tools should I order from. BUNNING? what's procedure to do the job? Thanks in advance!
Hello @Honest52
Thanks for sharing your question about painting your garage brick wall. I just wanted to be clear that there is no plaster on your brick wall. If it is just plain bricks, I suggest getting a bristle broom and sweeping the surface free of dust and debris. To fill the holes in the bricks, I recommend using Selleys 440g No More Gaps Bricks and Mortar Gap Filler. For chipped or cracked surfaces, I suggest Polyfilla 500g Exterior Brick and Render Masonry.
You'll need a paint brush to paint the mortar in between the bricks and a paint roller to cover the flat surfaces. Dulux Wash and Wear is suitable for internal masonry surfaces. However, you'll first need to apply a coat of Dulux 1Step Prep Primer, Sealer, & Undercoat to seal the brick wall.
Here are some helpful step-by-step guides:
