I'm hoping someone can explain the following;
I measured a PVC pipe I wanted a fitting for and it measured 40mm externally. When I bought a 40mm coupling it was too big?
40mm Coupling has an internal dimension of 47mm?
32mm PVC pipe has the dimensions 42mm externally and 36mm internally?
32mm Coupling that fits above is actually 42mm internally and fits my existing pipe better?
Existing pipe 40mm
40mm coupling is too big
32mm coupling fits 40mm pipe
32mm pipe is not 32mm
Is this a plumbers secret to confuse DIY'ers?
Cheers,
Stuart
