Hi, I have purchased some Billy bookcases from Ikea and want to set it up in my office. The bookcase needs to be fixed to the wall to avoid tipping over. How do I know if the wall has cables behind as the adjacent room has an air conditioning unit? What products should I use to fix it to the wall?
I also need to cut the hole for the baseboard slightly higher as my baseboard measures 1cm taller than the hole at the back, do you recommend using a hand saw to do this?
Thank you!
