Can the Hartman Half Umbrella fit into the Marquee 25kg Base or must it be the Hartman 45cm Base?
Hi @Robin510,
Thank you for your question and welcome to the Bunnings Workshop community, it is fantastic to have you with us.The Hartman Half Round Umbrella states that it has a 32mm diameter pole and the Marquee 25kg Concrete Umbrella Base suits 35-48mm diameter poles, so unfortunately it doesn't appear compatible.You could however use the Marquee 15kg Concrete Umbrella Base as it states it can be used for pole diameters from 30-38mm.
Let me know what you think.
I was just concerned about the Hartman weight Jacob - it looks very thin, so might go for the Marquee15kg.
Robin
That's understandable. If you wanted to increase the weight on the base, you could always add some Sand Bag Gazebo Weights or Base Pods Gazebo Weights for some peace of mind.
