Hi.
I'm constructing a full-sized Iron Man Alcove. Yes, really. And I am using 3d-look and other metallic vinyl wraps for effects.
To stick, these need a smooth surface, such as laminated panels used in kit furniture products. The issue is, I need a solid piece of wood for the back of the alcove and the kit I'm looking at buying from Bunnings, only has the flimsy 3mm ply. So I'm looking at buying a 2400mm x 1200mm x 17mm piece of Formrite-Formply, from you for the back. But, as this piece has the most important vinyl wrap decal, I need to know if there will be issues with the adhesive clinging well to such a surface.
Do you know?
Thanks.
Zach
