Hello,
We have done some minor DIY eg installed new kitchen and laundry (mostly flat packs), built some draws ourselves for custom fit etc.. But this project is more complicated.
Provided we get council approval, we would like to enclose the open wall of the back patio (raised section attached to house), as we have a sleepout type room that opens onto this, but isn't really used much because you have to go outside to access it. We have recently started a family so the extra space on patio could also serve as a safe playroom etc.
So thinking timber frame the areas between the metal posts, install sliding door and sliding aluminium windows (2nd hand) to cover most of area. Just wanted advice on a few problems;
- The existing roof doesn't cover the whole patio area, at the end there is an awkward area. I am not sure how to handle enclosing this corner
- Should we repair the concrete at the base of the poles (still very secure), and if so, how?
- Also any other tips on framing, window/door installation, insulation of ceiling (if possible?), or exterior cladding, would be great. The sun hits this area in the afternoon and is hot in summer, so I would probably install blinds to exterior but any other ideas would help
Feeling a bit over our heads but keen to get this to work!
Thank you
Looking north
Looking south
North side (roof doesn't cover whole area)
Pole/concrete support
