Hi Bunnings Folk.
I need to secure a galvanised trellis to a colour bond fence. I’ve got some galvanised panel fixing clips, and was originally planning on using galvanised bolts with them, but now prefer to use aluminium pop rivets if I can. Means I won’t have to invade the neighbour’s yard to get the job done. Problem is the holes in the fixing clips are close to the diameter of the rivet flange, so I plan to use M6 backup washers. Question is, should the washers be galvanised, s/steel, or aluminium? Or maybe it doesn’t matter? Bit concerned about any electrolytic reaction and/or corrosion. I live in a coastal area where corrosion is a big problem.
Thanks in advance, Mark
