I am in the process of repainting a bedroom that has soot from candle covering the walls and ceiling. When I first tried to clean up, I made the really bad mistake of wiping with sugar soap. Bad move!!
Having done a bit more research, the advice that seemed best was 1: vacuum with brush attachment (you can imagine doing that to the entire room), 2) clean with magic eraser 3) wash with degreaser / sugar soap.
I have now cleaned it as per, but there are some grey smears, some light some dark..
I read somewhere to prime with Zinsser Stain blocker.
My questions are
1) Do I need to apply Zinsser to the entire room or can I just prime the really bad areas?
2) Do I need to sand after priming?
3) Over all, for the walls, is it ok to first coat with Dulux ceiling white instead of having 2 coats of the wall paint
4) Is Wash and Wear low sheen better or should I go for flat?
Thanks very much for any advice.
