I'm carrying out repairs (for my senior friend) on a fibro shed, one job being replacing/ installing new corner mouldings on the external vertical corners..
I/we have purchased the Brutus product, and noticed that the internal face* of the 65mm x 65mm moulding, ( *which would be facing/ attached to the corner ) is less than 90 degrees.
Question #1: Should I press the moulding in towards the corner, so it sits flat/ flush to both surfaces and than secure with screws, or..........????
Question #2: My proposed method of attaching the moulding was using galv. buttonhead screws, pre-drilled thru the moulding + fibro +into hardwood frame. Is this method OK ?.
Question #3: When using this PVC product outdoors, exposed to NSW Central Coast weather, should allowances be made for expansion and contraction, and what method would you suggest ?
Would very much appreciate whatever advice and assistance you can offer.
Awaiting your (hopefully) prompt reply, as I have to complete all the work this coming weekend, hampered by the current adverse weather and my 70+yr old attempts as a handyman/ helper.
Cheers, Ricka
