does the The D - Tumbler Handle for 5 O'Clock Black fit a Mossey Oak 30oz stainless steel tumbler?
Hi @gjr868,
Thank you for your question and welcome to the Bunnings Workshop community, it is fantastic to have you with us.The D - Tumbler Handle for 5 O'Clock Black is designed for use with the 5 O'Clock Stainless Vacuum Insulated Tumbler, which indicates its dimensions are 8.5cm (w - top), 7cm (w - bottom) x 17.5cm (h).If the product you have mentioned has similar dimensions, you may be able to use it, but there is no guarantees it will fit.If you wanted to be sure it would work, I'd suggest getting the 5 O'Clock Tumbler with this product.
