How do you cut Bellessi splasback polymer. Also how to attack to a chipboard backing
Hi @Dirk,
Thank you for your question and welcome to the Bunnings Workshop community, it is fantastic to have you with us.I'd suggest you have a look through the Bellessi Installation Instructions which state that their panels can be cut with a circular saw. It should be fully supported using sawhorses and a flat material such as plywood to support the weight while cutting.You can then use a straight edge and clamps as a guide to get a nice straight cut. For holes, you can use any standard drill bit but be aware that drilling through plastic will blunt the drill bit quickly. For larger round holes, use a holesaw.To attach to a chipboard backing, make sure the surface is nice and clean by using sugar soap and a soft cloth to wipe any contaminants from the surface. You can then use a clear neutral cure silicone such as Selleys Translucent Interior Neutral Cure Silicone to adhere the splashback to the chipboard.
