I have replaced the laundry sink with a new one and simply wanted to connect to the existing plumbing. Do I need to have the sink drain in the exact same position or can I move or add pipes or connectors to complete the job
Welcome to the Bunnings Workshop community @robrobg. It's wonderful to have you join us, and many thanks for your question about installing a new sink.Depending on how the pipework needs to be adjusted, a plumber could use connectors to do so. If the adjustment is not possible with connectors, then they might need to install a new waste in the correct position. Without further details and some images of the setup, it's a bit hard to give you a definitive answer. Let me know if you need a hand uploading photos.
As this is considered plumbing work, you will need to enlist the services of a professional to complete the work.Please let me know if you have any questions.Mitchell
