I would like to replace my current rangehood with a similar type - fixed and slide out without ducting and not undermount. It measures 600x470x150mm approximately. It plugs into a power socket on the wall with a standard Australian style 3-pin plug.
Would this be a simple remove and install as I am unsure if the existing mounting points on the wall are suitable and unsure if new units came with the right plug on the end of the cable. Can you please shed a little light?
