Hi, I spray-painted my denim jeans a few times and even washed them after the paint dried but over time, my jeans have turned thicker and heavier.
I have used acrylic and enamel paint spray.
Is it normal? Thanks.
Hello @Cattoos
Thanks for sharing your question about your painted jeans. If you used the entire can of paint spray on your jeans, it's very likely that is has soaked into the fibres and made it stiff. This stiffness gives the illusion that your jeans have gone heavier. It's perfectly normal and there is nothing to be worried about. If you use your jeans often enough natural creases will occur on the jeans breaking up the paint and returning your jeans mobility.
Thanks. I did not use the whole spray can but only 5 to 10 sprays but over a couple of weeks. Also even after washing machine, the jeans is still heavy and thick now so just wanted to know if it is normal that is all. I am alright with jeans being heavy and thick but hopefully it is from the spray paint. thanks.
