I am having trouble with the finished product after installing the 1200mm Mondella Rococo white mirrored shaving cabinet with the pre installed hooks on the back. For starters the cabinet is 1200 wide, and my studs are 600 apart, but because the pre installed hooks are located 10mm in from the edge of the cabinet, they completely miss the studs. I used 4 x 40kg GRIPIT fixings in the villaboard wall (no tiles). I also put 3 long screws through the back of the cabinet into the middle stud it covered - so hoping for the best there!
My problem now is, the cabinet doesn't sit flush against the wall at the top. I used the inside cabinet holes to adjust the cabinet fixings as the instructions said, but the instructions do not give details as to which of the 2 screws does what exactly. I don't want to keep trying to adjust these willy nilly in case I cause damage. Can't find any instructions online anywhere! Please help.
