Hello..I would like some advice. I have two sets of french doors, but I would like to convert them into "real" french doors with the little panes of glass. Anyone that can help?
Hi @fclarke,
The Sika 310ml SuperGrip 30 Minute Adhesive is clear and suitable for sticking timber and aluminium to glass. Traditional French doors are created from individual glass panels, which are framed into the door with timber. If you were to add stick-on muntins, applying them to both sides of the glass will give you the most authentic look.
I look forward to following along with your project and seeing those pictures.
It looks like our members are keen to assist you with your project, which is fantastic.
You could cut and then attach Tasmanian Oak moulding or aluminium flat bar to the glass surface with Sika 310ml SuperGrip 30 Minute Adhesive. As glass panes come in a multitude of different sizes, I'm not sure how successful you'll be in finding pre-made lengths.
Personally, I've had experience with re-attaching muntins to a solid glass panel. I was in a rental property, and we managed to break a large glass panel on a sliding door that had a French door look. After ordering a new glass panel and fixing it into the frame, I removed the muntins off the cracked glass panel and re-glued them to the new one. These were aluminium, and I used translucent silicone. Irritatingly after hours of glueing them on, I placed a heater a few feet away to accelerate the dry time of the silicone. The new glass panel cracked, which I presume was due to the difference in heat between inside and outside as it was Winter.
As long as you used a fine-toothed saw and were reasonably accurate with your cuts, I believe you could achieve a fine finish on the project.
@StevieB @fclarke
Hi Stevie, thanks for tagging me in this post. fcclarke, before I give my suggestions I'd like to know what your rough budget is for this job and your experience? I only ask because that would make a difference in what I suggest to you.
Also could you post some pics do I can have a closer look at the job?
Cheers
Wouldy
Hi .@fclarke,
.@StevieB, @roofie, @Wouldy and @MitchellMc
I found this website that shows how to add Muntins to a glass door, hope it helps. Looks easy just go to Buunings and buy the style of timber moulding required. Porta make all types of moulding, available at Bunnings
https://thechelseaproject.com/how-to-easily-diy-custom-muntins-for-windows/
Joe
Thanks for contributing to this discussion.
Let me tag @roofie so they are alerted to your question. I'll also mention @JoeAzza, @Wouldy and @MitchellMc to see if they can offer any helpful suggestions to get you started.
In the meantime, could you please share a photo of your doors at the moment to give our community an idea of what you're starting with?
Keep us updated on your project. I'd love to hear how it goes and see pictures along the way.
Stevie
Hi Roofie I know it is a while since you posted this item but I am wondering if you had any success as I want to do exactly the same I am wondering if there is a stick on timber strip that would make the door appear as if it had separate panes of glass or if I will have to make these strips myself. ??
I wouldn't consider that an easy DIY job @roofie. I'd recommend you get a glazier in to quote the job.
I have two sets of french doors that lead out onto the patio. They already have the panes of glass in them. but instead of having the one sheet of glass I want to put a frame in the door to make them look like little english cottages french doors. So instead of having one pane of glass, it looks like mabe 6 little square panes in each door.
Hi @roofie,
Welcome to Workshop. We're pleased you could join us and trust you will receive loads of helpful advice and inspiration for your home improvement projects from our ever-helpful community members.
You might like to share a photo or two of both your doors and an example of the look you are after so other members can provide more detailed and useful advice. It would also be good to provide a little more detail about what you want to do and what you think you might have difficulty with.
Thanks again for joining in the discussion.
