Hi @Samara1
Cat 6 cable is fully shielded and will not be effected by speaker wires or anything else sort of a massive solar flare, and the same is true the cat 6 will not cause hum etc on speaker wires.
Just a tip label your camera wires for ease of servicing them in future.
Make sure the cat 6 cables long enough to allow attached unit to come out of the cabinet for servicing adding extra cameras etc later.
Hello @Samara1
That's excellent advice coming from @Jewelleryrescue. In regards to cable tags, I suggest looking at the Click Writeable Cord Identifiers as a convenient way of identifying the cables.
Some pretty wrong advice being given here. The cabling regulations state (I'm paraphrasing here as the regs are much longer winded in the current iteration) "fixed or concealed cabling SHALL NOT terminate on a plug" you have to fit a socket plate at least in order to comply with the law these are then patched to the PVR with patch cords. You can fit at most 6 outlets on a plate, so you need to divert the speaker cables to another outlet location. Oh and most cat 6 is UTP which means Unscreened twisted pair Screened is only used in special applications (STP) due to increased cost. the outlets are the ones usually tagged. Oh and if a professional did this get them back to fix it and have the regs handy as they should know this!
For the regulations (long read) see here.....
https://www.acma.gov.au/australian-cabling-standards
S009 is the technical standard
The relevant section is 5.9 Plug-terminated cabling
Hi @Samara1,As @R4addZ, who is a licensed cabler has said, there are strict standards in place for cabling, meaning advice on things of this nature should be given by professionals.There is a second hole in the right side of the cabinet, which has likely been put there to accommodate the different wires and different plates. I think it's important to note that this is not a finished job. There is no problem having unattached cables touching each other while waiting for fitoff, but if this was the state of a finished job, you should definitely be getting them back to fix their work as R4addz has said.Jacob
Sorry Guys I am The electronics professional 6 year training coarse things trained properly in the 80s @JacobZ extra 2 years as electrical course part time. Grand father taught my valves at age 14 now lol/
I am a fully quailfied electronics techo of over 40 years experiance and have work with high frequency transmission signals at Australian National University on equipment that you would not believe that now is used in space telescopes measure the distant spectrums of stars and galaxies where they cant run a cable yet.
Vs The current Open Cabler Registration course Duration 5 days.
I am technically up todate and beyond i would like to point out a product bunning sells that I used for cat 6A video cables so wifi POE cameras dont slow my wifi bandwidth. From Mesh Network modem a direct cable to PCs and cameras it works fantastic.
Made for pre made cables through the wall just as an example of changing standards and times. Better lock bunnings up for not only selling wall plates.
Wall plates are nearly obsolete in to the future dramatically slow data at every connection adds shielding issues and slows wave propegation and sends signal refections back up the line cat 8 cables must have a signal end to end connection points and metal sheilded plugs not the plastic rj45.
But 4G and 5G and beyond will be the real way of the future cable guys on the endangered species list.
I choose not to get into a debate and multiple proofs here as it isnt helping anyone. Just some facts.
Even cat 5 and 5e will operate with no problems in same location. as @Samara1 is using but camera date rates increasing weekly so put the highest sheilded standard you can afford. @Samara1 didnt specify UPT this is @R4addZ assumption but sheilding increases cable performance the lack of it wont be measurable out side of a science lab. . Technology always leads the rule changes catch up periodically is more af a guidle line so cabling companies tow the line pardon the pun.
Samara will never have any problems with there setup ever but into the future they may need (like all of us) higher standard wiring to support higher bandwidths.
Jewelleryrescue
If it's credentials we are looking for I have over 50 years experience in customer premises equipment (I trained originally in the 70s but have trained in this field continuously as it has developed) with a full apprenticeship with British Telecom and service with what is currently Telstra. I actually work in the field we are discussing but it isn't my credentials that matter, nor yours for that matter! The regulations I linked to are the only thing that matter.
Who in their right mind would use Cat7 or Cat8 cable for cctv connections have you looked at the prices for components for these networks? And what resolution will need such networks 4K cctv? not really sensible and with the lengths of cable runs for this kind of installation you could even do that with Cat6! Also shielding does not improve performance it simply protects you from such things as alien cross talk and other degrading interference which can also be dealt with by informed installation practices Have you truly considered the difference in cost between sheilded and unsheilded components as no one in their right mind would suggest this for a cctv install.
As for wall plates, they are required by law! how can you say they are nearly obsolete? fixed or concealed cabling is not allowed to terminate on a plug except under certain circumstances such as it not being accessible by the end user so sorry but you are totally out of order here!
Feel free to express an opinion but don't question the law when advising people what they can or can't do!
