Hi Team,
I am currently doing a kitchen upgrade.
I have one 600mm straight wall cabinet and a 600mm corner wall cabinet to attach along a wall that is 1235mm long. I also have an end panel and filler panel as the cabinets are not exactly the same size as the wall.
there were previously wall cabinets but they were very not fit for purpose and very inaccessible in the way they were arranged. Impossible to use in a meaningful way so they were just a waste of space.
The wall is pink gyprock with a metal frame of sorts behind it. I’ve found where I think the studs are but this may be incorrect given there’s that frame. I can’t physically see the studs and frame since the gyprock is intact except for a small hole where the power point. I have identified the location where the ac cables for this powerpoint come from/go to.
Some of the spots which were used to anchor the previous cabinet are in the right spot for the new cabinet so would it be ok to reuse the same points on the wall, or should I go a little above/below to reduce risk of failure within the gyprock?
For those that dont line up, would wallmates be appropriate, or would cleats work better in this situation?
