The Bunnings How to build a carport DIY doesn't include any lateral bracing. Is there sufficient strength in the post to beam joints to not require additional sideways bracing?
Welcome to the Bunnings Workshop community @Investigations. It's sensational to have you join us, and many thanks for your question about constructing a carport.Given the limited details provided, including the type of joints, how they’ll be connected, the calibre of timber used, the overall size, and the expected wind loads on the structure, it’s not possible to fully answer this question. For a safe and structurally sound design, it would be best to consult a draftsperson or engineer who can assess these factors accurately. They’ll be able to confirm if additional lateral bracing is needed to ensure stability in your carport structure.Please let me know if you have any questions.Mitchell
Hi Mitchell,
Thanks for your response. The type of joints are detailed in the Bunnings online DIY video and instructions.
https://www.bunnings.com.au/diy-advice/building-construction/roofing/how-to-build-a-carport?srsltid=AfmBOoqBCBCLvVVqZVpKklvZ4xDFuZOpkJLVnr3_tUfVqCQj9_GSqomj
I just found it odd that lateral bracing wasn't discussed and thought perhaps the joints were of a suitable standard to resist lateral loads, given there are no walls and minimal lateral loads.
Thanks anyway, I will consult an engineer.
Scott
Hi @Investigations,
The joints being rebated generally provide more resistance to lateral loads compared to a face-fixed beam. In a rebated joint, the beam is seated into a notch cut into the post, creating a physical barrier that helps resist movement in multiple directions. This design spreads the load more effectively and reduces the reliance on fasteners alone, making it stronger against lateral forces, especially in outdoor structures like pergolas, where wind loads can be a factor.
You'll also note that at one end of the carport, six posts are used, which adds exceptionally more rigidity to the structure than just two posts. If it were just the two posts, then lateral bracing would be a good idea. However, there's no reason why you couldn't add lateral bracing to this design, as you end up with a very solid structure.
Excellent response Mitchell! Thanks very much
