Hi folks
Hoping someone might be able to point me in the right direction?
I have an existing fence, and would ideally like to make a gate way there so I can enter the yard on both sides of my house.
I don't have a lot of space to play with and it would have to be strong, lockable/secure as on the other side is our pool, but I am so very over having to go all the way around to turn on a tap which is further back in the pool yard along the side of the house.
I can't afford to pay anyone to do this and wondering if I could get some pointers/suggestion to possibly tackle this job myself and on a tight budget.
1) I've added a few pics.
1a) The pic with the Yellow markings is where the gate would have to be, right up against the house/opening outwards.
2) The bricked out area on the ground, is where I've installed the large rainwater tank left of pic.
3) I'm limited as it's only wide enough to put a small gateway, only permitted to be no bigger than a metre.
4) On the other side is a small garden shed, with enough room to walk/between house and shed.
5) Below are some of the NSW Councils rules regarding gates into a pool yard, as a guide
In New South Wales (NSW), pool gates must meet the following regulations:
- Opening direction: Gates must open away from the pool
- Closing: Gates must be self-closing and self-latching, and must close automatically from any position
- Latch release: The latch release mechanism must be at least 1500 mm above the ground, or at least 150 mm below the top of the fence
- Gate width: Gates should be kept to a minimum width, no more than 1 meter
- No climbing: There should be no footholds or handholds closer than 90 cm apart
Appreciated any advice, as I've been searching online and can't seem to find a simple version or way around this task, I was hoping to have it look like just a panel in the fence, as I don't plan to be using it as a regular access point, but going into a pool yard may make that more difficult. *(I may give my local council a call to check).
Thanks in advance folks, any advice would be well and truly appreciated.
This Old-gal
Area required
No bigger then yellow area as Rainwater tank comes to bricked area
Inside view- gate will have to open outwards
